跳转到主内容
Triace A310 Brake Cable Replacement
你所需要的
  1. Triace A310 Brake Cable Replacement, Brake Cable: 步骤 1 中的图像 1,2 Triace A310 Brake Cable Replacement, Brake Cable: 步骤 1 中的图像 2,2
    • WARNING: Be sure to follow each step carefully. Failure to do so may result in serious injury or death.
    • Unscrew the screw holding the brake cable in place with a 5mm allen wrench and pull out the cable.
  2. Triace A310 Brake Cable Replacement: 步骤 2 中的图像 1,3 Triace A310 Brake Cable Replacement: 步骤 2 中的图像 2,3 Triace A310 Brake Cable Replacement: 步骤 2 中的图像 3,3
    • Unscrew the slotted brake cable cap on the rear tire and pull out the cable. Remove the cap from the cable.
  3. Triace A310 Brake Cable Replacement: 步骤 3 中的图像 1,2 Triace A310 Brake Cable Replacement: 步骤 3 中的图像 2,2
    • Unscrew the cap next to the brake handle and remove it from the cable.
  4. Triace A310 Brake Cable Replacement: 步骤 4 中的图像 1,3 Triace A310 Brake Cable Replacement: 步骤 4 中的图像 2,3 Triace A310 Brake Cable Replacement: 步骤 4 中的图像 3,3
    • Pull up and out on the cable to remove the barrel nipple (the small cylinder at the end of the cable).
  5. Triace A310 Brake Cable Replacement: 步骤 5 中的图像 1,3 Triace A310 Brake Cable Replacement: 步骤 5 中的图像 2,3 Triace A310 Brake Cable Replacement: 步骤 5 中的图像 3,3
    • Unscrew the bracket located on the front tire with a 3mm allen wrench.
    • Rotate the bracket 90 degrees or until the opening is large enough for the cable. Remove the cable.
    • Note that if removing cable for rear brake, rather than unscrewing a bracket, you will unclip several "spring" clips. Keep track of clips.
    • Test your brakes in a low-speed environment to ensure that they work.
结论
To place the new cable, follow these instructions in reverse order.
Ben Hartinger
于01/27/14注册
340 声望
创作了3篇指南
团队
Cal Poly, Team 1-37, Maness Winter 2014 Cal Poly, Team 1-37, Maness Winter 2014 的会员
CPSU-MANESS-W14S1G37
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 12
总计 339
