跳转到主内容
Trek 820 Tail Light Mounting Bracket Replacement
你所需要的
  1. Trek 820 Tail Light Mounting Bracket Replacement, Tail Light Mounting Bracket: 步骤 1 中的图像 1,1
    • Obtain one tail light mounting bracket and one screw as shown in the picture.
    • The screw should be removed from the mounting bracket.
  2. Trek 820 Tail Light Mounting Bracket Replacement: 步骤 2 中的图像 1,1
    • Clean the bicycle seat post and mounting bracket.
    • Wrap the mounting bracket strap around the seat post.
    • Verify the larger piece rests towards the tail end aligned with the tires.
    • Verify the bracket's screw hole is on the right side of the bicycle.
  3. Trek 820 Tail Light Mounting Bracket Replacement: 步骤 3 中的图像 1,2 Trek 820 Tail Light Mounting Bracket Replacement: 步骤 3 中的图像 2,2
    • Locate the slot on the bracket where the strap will be inserted.
    • Insert the strap into the slot.
    • Tighten the strap just enough to keep the bracket in place.
  4. Trek 820 Tail Light Mounting Bracket Replacement: 步骤 4 中的图像 1,2 Trek 820 Tail Light Mounting Bracket Replacement: 步骤 4 中的图像 2,2
    • Insert the screw into the bracket screw hole.
    • Tighten the screw with fingers until the mounting bracket rests freely on seat post.
结论
团队
Cal Poly, Team 1-1, Propen Fall 2012 Cal Poly, Team 1-1, Propen Fall 2012 的会员
CPSU-PROPEN-F12S1G1
5 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 1,139
