跳转到主内容
Trek 820 Light Mount Replacement
你所需要的
  1. Trek 820 Light Mount Replacement, Light Mount: 步骤 1 中的图像 1,2 Trek 820 Light Mount Replacement, Light Mount: 步骤 1 中的图像 2,2
    • Clean the area where the light mount will be installed with a soft cloth.
    • Placing the light mount close to the center stem.
  2. Trek 820 Light Mount Replacement: 步骤 2 中的图像 1,1
    • Remove the strap from the light mount fitting.
    • Stretch the strap clockwise around the handlebars.
  3. Trek 820 Light Mount Replacement: 步骤 3 中的图像 1,1
    • Slide the strap through the slot and fasten to a snug, but moveable fit.
    • Do not fasten too tight as this will make it difficult to fine tune light mount placement.
  4. Trek 820 Light Mount Replacement: 步骤 4 中的图像 1,1
    • Pull the strap tightly through the clasps at the bottom of the mount.
  5. Trek 820 Light Mount Replacement: 步骤 5 中的图像 1,2 Trek 820 Light Mount Replacement: 步骤 5 中的图像 2,2
    • Place the fastening screw in the rear screw port on the light mount.
    • Twist the screw clockwise using your hands until fully fastened.
结论
Now you have a light mount ready for safer night rides on your Trek bicycle!
团队
Cal Poly, Team 1-1, Propen Fall 2012 Cal Poly, Team 1-1, Propen Fall 2012 的会员
CPSU-PROPEN-F12S1G1
5 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 865
