跳转到主内容
加入维修社区 - 创建账户
Trek 6000 Brake Component Replacement
你所需要的
  1. Trek 6000 Brake Component Replacement, Trek 6000 Brake Component Replacement: 步骤 1 中的图像 1,1
    • Carefully flip bike over, balancing it on the handle bars and seat.
    • Use a level floor free of clutter.
  2. Trek 6000 Brake Component Replacement: 步骤 2 中的图像 1,1
    • Release the clamping mechanism that holds the front forks to the wheel bearing by twisting it 180 degrees.
  3. Trek 6000 Brake Component Replacement: 步骤 3 中的图像 1,2 Trek 6000 Brake Component Replacement: 步骤 3 中的图像 2,2
    • Remove the plastic nut that is located on the opposite side.
    • Remove the axle bolt and pay attention to the order and orientation of the springs.
  4. Trek 6000 Brake Component Replacement: 步骤 4 中的图像 1,1
    • Remove the front wheel from the forks by lifting it straight up.
  5. Trek 6000 Brake Component Replacement: 步骤 5 中的图像 1,2 Trek 6000 Brake Component Replacement: 步骤 5 中的图像 2,2
    • Remove the 6 screws holding the brake rotor to the front wheel using the T25 Torx driver.
    • When installing the new brake rotor, be sure to orient the arrow shown in the wheel's direction of travel.
  6. Trek 6000 Brake Component Replacement: 步骤 6 中的图像 1,3 Trek 6000 Brake Component Replacement: 步骤 6 中的图像 2,3 Trek 6000 Brake Component Replacement: 步骤 6 中的图像 3,3
    • Loosen the brake cable clamp using the 5mm allen wrench until the cable can be pulled free.
    • Remove the two screws holding the caliper to the front fork using the 5mm allen wrench. Be sure to pay attention to the order and orientation of the washers.
  7. Trek 6000 Brake Component Replacement: 步骤 7 中的图像 1,1
    • Remove the cable by twisting the black plastic cable guide out of the hole.
    • Align the channels on the guide and the nut to free the cable.
结论
To reassemble your bike, follow these instructions in reverse order.
Mario Maraccini
于09/24/17注册
101 声望
撰写一个指南
团队
Michigan Tech, Team S5-G8, Galliah Fall 2017 Michigan Tech, Team S5-G8, Galliah Fall 2017 的会员
MTU-GALLIAH-F17S5G8
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 826
