跳转到主内容
Trek 4300 Bicycle Rear Wheel Replacement
  1. Trek 4300 Bicycle Rear Wheel Replacement, Rear Wheel: 步骤 1 中的图像 1,1
    • Stand behind your bike straddling the rear wheel and locate the brake calipers.
    • To lessen the tension on the brake wire, place one hand on each caliper and push them towards one another.
  2. Trek 4300 Bicycle Rear Wheel Replacement: 步骤 2 中的图像 1,2 Trek 4300 Bicycle Rear Wheel Replacement: 步骤 2 中的图像 2,2
    • Unhook the brake wire in the metal tube from the brake wire holder on the caliper in your left hand.
  3. Trek 4300 Bicycle Rear Wheel Replacement: 步骤 3 中的图像 1,2 Trek 4300 Bicycle Rear Wheel Replacement: 步骤 3 中的图像 2,2
    • Find the quick release lever located on the wheel's fork.
    • Open the leaver 180 degrees from the locked position.
    • Spin the lever counterclockwise a few turns to loosen the pin while holding the opposite of the pin.
  4. Trek 4300 Bicycle Rear Wheel Replacement: 步骤 4 中的图像 1,2 Trek 4300 Bicycle Rear Wheel Replacement: 步骤 4 中的图像 2,2
    • Pull the bike frame upward off the wheel fork to separate it from the rear wheel.
    • Remove the bottom chain from around the rear cassette on the wheel.
  5. Trek 4300 Bicycle Rear Wheel Replacement: 步骤 5 中的图像 1,1
    • In reassembly, lay the top chain on the lowest gear on the rear cassette. Then follow the steps in reverse order beginning with step 3.
结论
To reassemble your device, lay the top chain on the smallest gear of the rear cassette and then follow the steps in reverse order beginning with step 3.
另外一个人完成了本指南。
Emily OConnor
于10/13/14注册
500 声望
创作了4篇指南
团队
Clemson, Team 3-2, Benson Fall 2014 Clemson, Team 3-2, Benson Fall 2014 的会员
CLEM-BENSON-F14S3G2
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 37
总计 3,148
