跳转到主内容
Trek 4300 Bicycle Kickstand Replacement
你所需要的
  1. Trek 4300 Bicycle Kickstand Replacement, Loosen Bracket: 步骤 1 中的图像 1,2 Trek 4300 Bicycle Kickstand Replacement, Loosen Bracket: 步骤 1 中的图像 2,2
    • Flip the bike over so it is balanced and resting on the handlebar and the bike seat.
    • Using a socket screwdriver with a hex adapter, loosen the bolt that is holding the kickstand and bracket in place.
    • This may require a moderate amount of strength. Make sure you have the proper hex adapter as to not strip the bolt.
  2. Trek 4300 Bicycle Kickstand Replacement, Remove the kickstand: 步骤 2 中的图像 1,2 Trek 4300 Bicycle Kickstand Replacement, Remove the kickstand: 步骤 2 中的图像 2,2
    • Once the bolt is loose, unscrew it the rest of the way by hand.
    • Remove the bolt. There should now be three separate pieces: the bolt, the bracket, and the kickstand.
    • Make sure to note the position of the bracket before you remove the bolt completely
结论
To replace the new kickstand, follow these instructions in reverse order.
Emily OConnor
于10/13/14注册
500 声望
创作了4篇指南
团队
Clemson, Team 3-2, Benson Fall 2014 Clemson, Team 3-2, Benson Fall 2014 的会员
CLEM-BENSON-F14S3G2
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 21
总计 2,822
