跳转到主内容
Trek 4300 Bicycle Front Wheel Replacement
  1. Trek 4300 Bicycle Front Wheel Replacement, Front Wheel: 步骤 1 中的图像 1,2 Trek 4300 Bicycle Front Wheel Replacement, Front Wheel: 步骤 1 中的图像 2,2
    • Stand facing your bike and locate the brake calipers.
    • To lessen the tension on the brake wire, place one hand on each caliper and push them closer together.
  2. Trek 4300 Bicycle Front Wheel Replacement: 步骤 2 中的图像 1,2 Trek 4300 Bicycle Front Wheel Replacement: 步骤 2 中的图像 2,2
    • Unhook the brake wire in the metal tube from the brake wire holder on the brake caliper in your left hand.
  3. Trek 4300 Bicycle Front Wheel Replacement: 步骤 3 中的图像 1,1
    • Find the quick release lever located on the bikes fork to loosen the wheel from the frame.
    • Lift the lever from lock position 180 degrees until the open sign on the lever faces outward. Twist the lever while holding the pin on the opposite side of the wheel.
    • The quick release lever does not need to be completely removed.
    • Note which side of the bike the quick release lever is on for proper reassembly.
  4. Trek 4300 Bicycle Front Wheel Replacement: 步骤 4 中的图像 1,2 Trek 4300 Bicycle Front Wheel Replacement: 步骤 4 中的图像 2,2
    • Pull the frame of the bike upwards to separate the front wheel.
结论
另外一个人完成了本指南。
Erin Ferguson
于10/13/14注册
447 声望
创作了4篇指南
团队
Clemson, Team 3-2, Benson Fall 2014 Clemson, Team 3-2, Benson Fall 2014 的会员
CLEM-BENSON-F14S3G2
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 21
总计 2,510
