简介
This guide will give you the know-how on how to transfer over photos from your Camera/SD card to your Apple Device
Notice: Steps/recommended adapters were sourced from this apple document
Supported SD cards and image-transfer protocols
- Picture Transfer Protocol (PTP)
- Mass Storage Device protocol
- SDSC
- SDHC
- miniSD
- microSD
- MMC
- SDXC
Flash or USB thumb drives aren't supported for image importing.
If you're using a Lightning to USB 3 Camera Adapter, these iPad models transfer data at USB 3 speeds:
- iPad Pro 12.9-inch (2nd generation)
- iPad Pro 10.5-inch
All other adapters and iOS devices use USB 2 speeds.
Connect the adapter to your device. The male connecter of the adapter will go into the Apple device.
If the previous steps were done correctly, you should see a tab called Import. Photos should automatically open to the Import tab. If it doesn't, open Photos and tap Import.
Next, Tap Import All to import your content, or tap specific items, then tap Import
When the import is complete, you might be asked to Keep or Delete the media on the camera or SD card
One you have imported your photos and chose to keep or delete the imported photos on your Apple Device, remove the SD card, followed by the adapter connected to your device
If you don't see the Import tab, follow these steps:
Make sure that your digital camera is on and in the correct mode to export images.
Disconnect the adapter, wait 30 seconds, then reconnect it.
Unplug the digital camera or SD card, wait 30 seconds, then reconnect.
Restart your iOS device and turn your camera off and back on.
If one is available, test with a different digital camera or SD card. If you can import media with a different digital camera or SD card, there might be an issue with the data on the camera or SD card. Try to import the data to another device or computer, then use your digital camera to format—or reset—the SD card.
1指南评论
Thanks for the guide. Could we get a teardown of the lightning to usb adapter though?
