跳转到主内容
Toyota Yaris Key Battery Replacement
你所需要的
  1. Toyota Yaris Key Battery Replacement, Remove Key: 步骤 1 中的图像 1,3 Toyota Yaris Key Battery Replacement, Remove Key: 步骤 1 中的图像 2,3 Toyota Yaris Key Battery Replacement, Remove Key: 步骤 1 中的图像 3,3
    • Release latch on back of key and pull from key ring to remove the backup metal key from the rest of the fob.
  2. Toyota Yaris Key Battery Replacement, Split key fob: 步骤 2 中的图像 1,2 Toyota Yaris Key Battery Replacement, Split key fob: 步骤 2 中的图像 2,2
    • Using a knife or small flat blade screwdriver pry open the two halves of the key.
    • To avoid cosmetic damage start from the inside where the metal key was removed in the previous step.
  3. Toyota Yaris Key Battery Replacement, Remove battery cover: 步骤 3 中的图像 1,2 Toyota Yaris Key Battery Replacement, Remove battery cover: 步骤 3 中的图像 2,2
    • Remove black circular cover, underneath is an O-ring and the battery.
  4. Toyota Yaris Key Battery Replacement, Replace Battery: 步骤 4 中的图像 1,1
    • Battery can easily be removed and replaced. Using CR2025 3V battery, ensure writing is visible with battery installed.
    • To reassemble reverse steps, install battery cover, snap the two halves together and push metal key back into its receptacle (no tools required for reassembly).
结论
Wieli
于01/08/23注册
2,141 声望
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 37
过去 30 天: 202
总计 1,550
