跳转到主内容
Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement
你所需要的
  1. Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Unscrew the front bumper: 步骤 1 中的图像 1,2 Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Unscrew the front bumper: 步骤 1 中的图像 2,2
    • Unscrew the cross-head screws which attach the front bumper to the car.
    • There are 4 screws to remove.
    • If you're only changing one headlight you need only unscrew one side. But for your peace of mind I'd advise you to remove them all.
  2. Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Wheel arch screw: 步骤 2 中的图像 1,2 Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Wheel arch screw: 步骤 2 中的图像 2,2
    • Unscrew the cross-head screw in the wheel arch.
    • You can use either a spanner, or a cross-head screwdriver.
  3. Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Central bumper attachment: 步骤 3 中的图像 1,2 Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Central bumper attachment: 步骤 3 中的图像 2,2
    • Release the plastic clip which attaches the top of the bumper to the middle of the radiator grill.
  4. Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Bumper removal: 步骤 4 中的图像 1,3 Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Bumper removal: 步骤 4 中的图像 2,3 Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Bumper removal: 步骤 4 中的图像 3,3
    • Disengage the the bumper attachment.
    • Using a large screwdriver or a small iron bar, lever it as shown until it detaches.
    • There are 2 attachments to release either side of the bonnet lock.
    • If you're only changing one headlight you only need to detach one side.
    • Completely disengage the bumper from around the headlight, pulling it gently outwards.
  5. Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement: 步骤 5 中的图像 1,2 Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement: 步骤 5 中的图像 2,2
    • Remove the cross-head screw on the side of the headlight (at the front).
    • Also remove the cross-head screw from the top of the headlight.
  6. Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement: 步骤 6 中的图像 1,2 Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement: 步骤 6 中的图像 2,2
    • Lift the top attachment of the headlight.
    • Disengage the headlamp, pulling it forwards.
    • Be careful - the bulbs are still connected. Don't pull the headlight too far forward.
  7. Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Indicator bulb: 步骤 7 中的图像 1,2 Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Indicator bulb: 步骤 7 中的图像 2,2
    • Turn the indicator bulb connector a quarter turn counter-clockwise.
    • Remove the indicator bulb.
  8. Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Main beam bulb: 步骤 8 中的图像 1,1
    • Withdraw the rubber boot on the back of the main beam bulb.
    • Unclip the clip which attaches the main beam bulb and remove the main beam bulb.
  9. Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Side light: 步骤 9 中的图像 1,1
    • Twist the side light connector a quarter towards counter-clockwise.
    • Withdraw the side light.
  10. Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Dip motor: 步骤 10 中的图像 1,1
    • Twist headlight dip motor a quarter towards counter-clockwise.
    • Withdraw the dip motor.
    • On reassembly, take care to secure the motor properly in position. An adjustment may prove necessary to ensure the position of the dashboard control corresponds to the correct level of dip.
  11. Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Reassembly notes: 步骤 11 中的图像 1,3 Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Reassembly notes: 步骤 11 中的图像 2,3 Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Reassembly notes: 步骤 11 中的图像 3,3
    • To reassemble your headlight, take care to correctly position the headlight, before reassembling the bulbs, dip motor, and screws.
    • Make sure the plastic pin on the side of the headlamp is properly inserted into the bodywork.
结论
To reassemble, follow the steps in reverse order.
4等其他人完成本指南。
由衷感谢以下译者:
fr en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
2条评论
Merci beaucoup pour ce tuto qui nous a bien servi.
Isabelle Gueguen - 回复
Merci pour le tutoriel qui m'a été d'une grande aide !
Sevan KEVORKIAN - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 55
过去 30 天: 197
总计 15,540
