跳转到主内容
Toyota Corolla Headlight/ignition key buzzer disable
你所需要的
  1. Toyota Corolla Headlight/ignition key buzzer disable, Toyota Corolla Headlight/ignition key buzzer disable: 步骤 1 中的图像 1,2 Toyota Corolla Headlight/ignition key buzzer disable, Toyota Corolla Headlight/ignition key buzzer disable: 步骤 1 中的图像 2,2
    • Start by removing the hood over the instrument cluster. Pull the hood straight out towards the steering wheel.
  2. Toyota Corolla Headlight/ignition key buzzer disable: 步骤 2 中的图像 1,2 Toyota Corolla Headlight/ignition key buzzer disable: 步骤 2 中的图像 2,2
    • After removing the hood, undo the four screws securing the instrument cluster and pull forward.
    • The buzzer is accessed through a grill in the bottom of the instrument cluster/combination meter. Simply poke a sharp object into the grill and mash up the speaker dome to neutralize the buzzer!
结论
7等其他人完成本指南。
bt1993
于02/13/13注册
372 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 66
总计 7,926
