跳转到主内容
Toy Windmill Repair
你所需要的
  1. Toy Windmill Repair, Toy Windmill Repair: 步骤 1 中的图像 1,1
    • Use the 120 grit sandpaper to remove any rough edges on both the base unit and any parts which need to be connected to it.
  2. Toy Windmill Repair: 步骤 2 中的图像 1,1
    • Use the rough sandpaper on parts that need to be connected to the primary unit as this will result in greater surface contact.
  3. Toy Windmill Repair: 步骤 3 中的图像 1,2 Toy Windmill Repair: 步骤 3 中的图像 2,2
    • Apply a small amount of wood glue to each end.
    • Connect the two pieces and apply a small amount of masking tape to hold them in place.
  4. Toy Windmill Repair: 步骤 4 中的图像 1,1
    • Once all the pieces have been connected and the glue has cured, use the fine sandpaper to smooth out the connected pieces.
  5. Toy Windmill Repair: 步骤 5 中的图像 1,1
    • Using the fill stick crayon, blend in the connected pieces.
    • This will require the reader to be creative.
  6. Toy Windmill Repair: 步骤 6 中的图像 1,2 Toy Windmill Repair: 步骤 6 中的图像 2,2
    • Apply a small amount of wood glue to each end of the windmill.
    • Connect the two pieces and apply a small amount of masking tape to hold the two ends in place.
结论
To reassemble your device, follow these instructions in order.
Karim Ladha
于06/27/21注册
133 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 28
总计 305
