跳转到主内容
TotalPond Pond Pump Impeller Spindle Replacement
  1. TotalPond Pond Pump Impeller Spindle Replacement, Impeller Spindle: 步骤 1 中的图像 1,3 TotalPond Pond Pump Impeller Spindle Replacement, Impeller Spindle: 步骤 1 中的图像 2,3 TotalPond Pond Pump Impeller Spindle Replacement, Impeller Spindle: 步骤 1 中的图像 3,3
    • Hold the inlet screen and rotate it counterclockwise to unscrew it. It is helpful to remove the inlet screen so that it is not damaged during the replacement process.
  2. TotalPond Pond Pump Impeller Spindle Replacement: 步骤 2 中的图像 1,3 TotalPond Pond Pump Impeller Spindle Replacement: 步骤 2 中的图像 2,3 TotalPond Pond Pump Impeller Spindle Replacement: 步骤 2 中的图像 3,3
    • Firmly hold the pump block with one hand and the impeller housing with the other hand. Rotate impeller housing counterclockwise until it is released.
  3. TotalPond Pond Pump Impeller Spindle Replacement: 步骤 3 中的图像 1,2 TotalPond Pond Pump Impeller Spindle Replacement: 步骤 3 中的图像 2,2
    • Remove the rubber stop that is attached to the tube that runs through the middle of the impeller. Also remove the bearing that is between the stop and the impeller.
  4. TotalPond Pond Pump Impeller Spindle Replacement: 步骤 4 中的图像 1,2 TotalPond Pond Pump Impeller Spindle Replacement: 步骤 4 中的图像 2,2
    • Hold the impeller cover with one hand and the impeller with the other. Slide the impeller out.
  5. TotalPond Pond Pump Impeller Spindle Replacement: 步骤 5 中的图像 1,2 TotalPond Pond Pump Impeller Spindle Replacement: 步骤 5 中的图像 2,2
    • Hold the impeller spindle and wiggle it side to side until it detaches from the impeller cover.
结论
另外一个人完成了本指南。
Nicole Santana
于01/13/15注册
597 声望
创作了5篇指南
团队
USF Tampa, Team 3-6, Hickman Winter 2015 USF Tampa, Team 3-6, Hickman Winter 2015 的会员
USFT-HICKMAN-W15S3G6
4 名成员
创作了5篇指南
一条评论
The part number of the spindle itself would probably be a good idea to included in this guide.
rz22g - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 12
总计 1,327
