跳转到主内容
TotalPond Pond Pump Impeller Rubber Stop Replacement
  1. TotalPond Pond Pump Impeller Rubber Stop Replacement, Impeller Rubber Stop: 步骤 1 中的图像 1,3 TotalPond Pond Pump Impeller Rubber Stop Replacement, Impeller Rubber Stop: 步骤 1 中的图像 2,3 TotalPond Pond Pump Impeller Rubber Stop Replacement, Impeller Rubber Stop: 步骤 1 中的图像 3,3
    • Hold the inlet screen and rotate it counterclockwise to unscrew it. It is helpful to remove the inlet screen so that it is not damaged during the replacement process.
  2. TotalPond Pond Pump Impeller Rubber Stop Replacement: 步骤 2 中的图像 1,3 TotalPond Pond Pump Impeller Rubber Stop Replacement: 步骤 2 中的图像 2,3 TotalPond Pond Pump Impeller Rubber Stop Replacement: 步骤 2 中的图像 3,3
    • Firmly hold the pump block with one hand and the impeller housing with the other hand. Rotate impeller housing counterclockwise until it is released.
  3. TotalPond Pond Pump Impeller Rubber Stop Replacement: 步骤 3 中的图像 1,2 TotalPond Pond Pump Impeller Rubber Stop Replacement: 步骤 3 中的图像 2,2
    • Remove the rubber stop that is attached to the tube that runs through the middle of the impeller.
结论
另外一个人完成了本指南。
Nicole Santana
于01/13/15注册
597 声望
创作了5篇指南
团队
USF Tampa, Team 3-6, Hickman Winter 2015 USF Tampa, Team 3-6, Hickman Winter 2015 的会员
USFT-HICKMAN-W15S3G6
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 9
总计 625
