跳转到主内容
Toshiba Thrive Speakers Replacement
你所需要的
  1. Toshiba Thrive Speakers Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Make sure the lock switch for the back cover is unlocked.
    • The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
  2. Toshiba Thrive Speakers Replacement: 步骤 2 中的图像 1,2 Toshiba Thrive Speakers Replacement: 步骤 2 中的图像 2,2
    • Remove back cover by prying away from the Thrive.
    • The easiest place to pry from is one of the two speakers.
  3. Toshiba Thrive Speakers Replacement: 步骤 3 中的图像 1,1
    • To remove the battery, make sure the lock switch is in the unlocked position.
    • The battery is unlocked when the switch is slid to the unlocked position.
  4. Toshiba Thrive Speakers Replacement: 步骤 4 中的图像 1,3 Toshiba Thrive Speakers Replacement: 步骤 4 中的图像 2,3 Toshiba Thrive Speakers Replacement: 步骤 4 中的图像 3,3
    • Slide the battery switch release to the right.
    • While holding the switch in place, lift up the battery.
  5. Toshiba Thrive Speakers Replacement, Speakers: 步骤 5 中的图像 1,2 Toshiba Thrive Speakers Replacement, Speakers: 步骤 5 中的图像 2,2
    • Start by using a PH0 phillips head screwdriver to remove the 12 screws holding on the back cover
    • All of these screws are identical so don't worry about getting them mixed up.
  6. Toshiba Thrive Speakers Replacement: 步骤 6 中的图像 1,3 Toshiba Thrive Speakers Replacement: 步骤 6 中的图像 2,3 Toshiba Thrive Speakers Replacement: 步骤 6 中的图像 3,3
    • Start to gently pry the back of the device off, while leaving it loosely in place.
    • Be careful not to tear or damage the cables when removing the back.
  7. Toshiba Thrive Speakers Replacement: 步骤 7 中的图像 1,3 Toshiba Thrive Speakers Replacement: 步骤 7 中的图像 2,3 Toshiba Thrive Speakers Replacement: 步骤 7 中的图像 3,3
    • Once the back of the case is off, disconnect the wires by gently pulling on the plastic tabs as shown.
  8. Toshiba Thrive Speakers Replacement: 步骤 8 中的图像 1,2 Toshiba Thrive Speakers Replacement: 步骤 8 中的图像 2,2
    • carefully open the device like a book and lay the two halves beside each other.
    • put the screen assembly in a safe place as you complete the rest of the guide.
  9. Toshiba Thrive Speakers Replacement: 步骤 9 中的图像 1,2 Toshiba Thrive Speakers Replacement: 步骤 9 中的图像 2,2
    • Use the plastic opening tool to open the latch holding the last wire to the back of the device.
  10. Toshiba Thrive Speakers Replacement: 步骤 10 中的图像 1,3 Toshiba Thrive Speakers Replacement: 步骤 10 中的图像 2,3 Toshiba Thrive Speakers Replacement: 步骤 10 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Remove the two screws holding the speakers in place. The screws are 3mm in length and require a PH0 screwdriver.
    • Using a pair of tweezers, remove the speaker.
  11. Toshiba Thrive Speakers Replacement: 步骤 11 中的图像 1,3 Toshiba Thrive Speakers Replacement: 步骤 11 中的图像 2,3 Toshiba Thrive Speakers Replacement: 步骤 11 中的图像 3,3
    • Use the tweezers to help you remove the speaker wire from the clips holding them in place.
    • After removal place the left speaker on the side.
  12. Toshiba Thrive Speakers Replacement: 步骤 12 中的图像 1,3 Toshiba Thrive Speakers Replacement: 步骤 12 中的图像 2,3 Toshiba Thrive Speakers Replacement: 步骤 12 中的图像 3,3
    • Use the tweezers again to help you remove the right speaker from its position.
    • Use a plastic opening tool to pull the connector connecting the speaker to the motherboard out of its port.
结论
另外一个人完成了本指南。
Ivan Williams
于09/22/14注册
133 声望
撰写一个指南
团队
USF Tampa, Team 10-1, Brown Fall 2014 USF Tampa, Team 10-1, Brown Fall 2014 的会员
USFT-BROWN-F14S10G1
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 351
