跳转到主内容
Toshiba Thrive 4G Speaker Replacement
你所需要的
  1. Toshiba Thrive 4G Speaker Replacement, Removing Outer Shell: 步骤 1 中的图像 1,1
    • To remove the outer casing, wedge the pry tool in between the front and back panel, and pull them apart.
  2. Toshiba Thrive 4G Speaker Replacement, Unlock the Battery: 步骤 2 中的图像 1,1
    • Locate the lock switch, at the top left corner of the device, and adjust to the unlocked position. (from left to right)
  3. Toshiba Thrive 4G Speaker Replacement, Take Battery Out: 步骤 3 中的图像 1,2 Toshiba Thrive 4G Speaker Replacement, Take Battery Out: 步骤 3 中的图像 2,2
    • Use your fingers to push the release switch, which is located at the top right corner of the device to the right.
    • While pushing the release switch to the right, use your other hand to pull the battery away from the inner casing.
  4. Toshiba Thrive 4G Speaker Replacement, Replace Battery: 步骤 4 中的图像 1,1
    • To replace the battery, take your replacement piece and flip it upside down, revealing the warnings and specifications of that specific battery.
    • Locate the crevice at the bottom of the battery, which has black openings in it.
    • Line up the black openings with the golden prongs located on the inner casing, and slide the battery into place.
    • Move the lock/unlock switch to the locked position
  5. Toshiba Thrive 4G Speaker Replacement, Remove Inner Casing: 步骤 5 中的图像 1,3 Toshiba Thrive 4G Speaker Replacement, Remove Inner Casing: 步骤 5 中的图像 2,3 Toshiba Thrive 4G Speaker Replacement, Remove Inner Casing: 步骤 5 中的图像 3,3
    • Follow the steps outlined in the battery replacement guide to remove the outer casing, and the battery from their position
    • Locate and remove the 14 screws that are located along the outer edge of the tablet. To do this use the a phillips #0 screwdriver.
    • Use the pry tool to loosen the bond between the inner casing and the metal shell below the plastic casing. To do this place the pry tool between the two surfaces and push up.
    • Repeat the last step on each side of the tablet
    • When the plastic casing becomes loose enough you can pull it off using your hands
  6. Toshiba Thrive 4G Speaker Replacement, Detach Ribbons: 步骤 6 中的图像 1,2 Toshiba Thrive 4G Speaker Replacement, Detach Ribbons: 步骤 6 中的图像 2,2
    • When lifting the plastic casing up you will notice multiple ribbons attached to the metal shell.
    • Use the pry tool to gently lift up the tape holding the ribbons down
    • You can now safely lift the rest of the plastic shell up off of the device
  7. Toshiba Thrive 4G Speaker Replacement, Remove the Camera: 步骤 7 中的图像 1,3 Toshiba Thrive 4G Speaker Replacement, Remove the Camera: 步骤 7 中的图像 2,3 Toshiba Thrive 4G Speaker Replacement, Remove the Camera: 步骤 7 中的图像 3,3
    • To remove the camera you must first remove one screw that is holding it in place. You will need the phillips #0 screwdriver to complete this step
    • Next you must detach the ribbon connected to the camera. To do this use the pry tool to gently lift the tape out of place
    • Next use the pry tool to lift the rest of the camera off of the platform
  8. Toshiba Thrive 4G Speaker Replacement, Locate the speakers: 步骤 8 中的图像 1,1
    • The speakers are located on the right side of the device. There is one speaker towards the top of the device and one on the bottom, just below the volume control buttons.
  9. Toshiba Thrive 4G Speaker Replacement, Detach Cord: 步骤 9 中的图像 1,2 Toshiba Thrive 4G Speaker Replacement, Detach Cord: 步骤 9 中的图像 2,2
    • Once locating the speaker, detach the wire that is connected to the logic board.
    • Use the pry tool to pull the cord away from the logic board.
  10. Toshiba Thrive 4G Speaker Replacement, Remove Top Speaker: 步骤 10 中的图像 1,2 Toshiba Thrive 4G Speaker Replacement, Remove Top Speaker: 步骤 10 中的图像 2,2
    • Locate the screw holding the speaker in place. It will be located at the bottom edge of the speaker.
    • Use the phillips #0 screwdriver to remove the screw
    • Use the pry tool to remove the speaker from the board.
  11. Toshiba Thrive 4G Speaker Replacement, Remove the Wiring: 步骤 11 中的图像 1,1
    • The top speaker is connected to the bottom speaker through a black wire.
    • Pull the wire out of place with your fingers, until you reach the second speaker which is just below where the volume control buttons are located.
  12. Toshiba Thrive 4G Speaker Replacement, Remove Second Speaker: 步骤 12 中的图像 1,3 Toshiba Thrive 4G Speaker Replacement, Remove Second Speaker: 步骤 12 中的图像 2,3 Toshiba Thrive 4G Speaker Replacement, Remove Second Speaker: 步骤 12 中的图像 3,3
    • Removing the second speaker is the same as removing the first speaker.
    • Locate the screw and unscrew the speaker, using the phillips #0 screwdriver.
    • Use the pry tool to remove the speaker from it's place
结论
Courtney Campbell
于10/22/14注册
301 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-1, Shastany Fall 2014 UMass Dartmouth, Team 1-1, Shastany Fall 2014 的会员
UMASSD-SHASTANY-F14S1G1
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 188
