跳转到主内容
Toshiba Tecra 8200 Hard Drive Replacement
你所需要的
  1. Toshiba Tecra 8200 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off the device and unplug the power cord.
    • To remove the battery, flip the device, so that the bottom is facing upward.
  2. Toshiba Tecra 8200 Hard Drive Replacement: 步骤 2 中的图像 1,3 Toshiba Tecra 8200 Hard Drive Replacement: 步骤 2 中的图像 2,3 Toshiba Tecra 8200 Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Slide the battery to the right side until you hear a click.
    • Carefully remove the battery from its compartment.
  3. Toshiba Tecra 8200 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,3 Toshiba Tecra 8200 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 2,3 Toshiba Tecra 8200 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 3,3
    • Locate the hard drive panel.
    • Remove the single screw labeled F4 by using a Philips size #00 screwdriver.
    • Save the screw, as it will be needed for reassembly.
    • Remove the panel, exposing the hard drive.
  4. Toshiba Tecra 8200 Hard Drive Replacement: 步骤 4 中的图像 1,2 Toshiba Tecra 8200 Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Pull the tab to remove the hard drive.
    • Insert the new hard drive by pushing it into the compartment, leaving the new "pull" tab exposed.
  5. Toshiba Tecra 8200 Hard Drive Replacement: 步骤 5 中的图像 1,2 Toshiba Tecra 8200 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Tuck the "pull" tab back into the hard drive compartment.
    • Replace the panel.
    • Replace the single F4 screw.
  6. Toshiba Tecra 8200 Hard Drive Replacement: 步骤 6 中的图像 1,3 Toshiba Tecra 8200 Hard Drive Replacement: 步骤 6 中的图像 2,3 Toshiba Tecra 8200 Hard Drive Replacement: 步骤 6 中的图像 3,3
    • Identify the connector pins on the battery.
    • Line up the connector pins on the battery with the connector pins on the computer and push inward to reconnect the battery.
    • Slide the exterior panel towards the center of the computer to lock the battery in place.
终点
Sally
于02/17/15注册
306 声望
创作了3篇指南
团队
Ohio State, Team 1-3, Buehl Winter 2015 Ohio State, Team 1-3, Buehl Winter 2015 的会员
OSU-BUEHL-W15S1G3
3 名成员
创作了9篇指南
一条评论
Awesome Thanks!
Erin Dulac - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 21
总计 2,237
