跳转到主内容
Toshiba Tecra 8100 Keyboard Replacement
你所需要的
  1. Toshiba Tecra 8100 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Open the laptop.
  2. Toshiba Tecra 8100 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Locate the long, thin plastic panel above the keyboard. This panel is positioned between the top of the keyboard and the screen of the laptop.
  3. Toshiba Tecra 8100 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Use the flathead screwdriver to gently pry the panel away from the laptop.
  4. Toshiba Tecra 8100 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Removing the panel will reveal a plug that connects the keyboard to the motherboard. Disconnect this plug.
  5. Toshiba Tecra 8100 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Once the keyboard is unplugged, gently pull it off. It should easily remove from the laptop. Replace this with the new keyboard. Plug the new keyboard in and replace the plastic panel.
结论
另外一个人完成了本指南。
[deleted]
于09/30/15注册
122 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 407
