简介
The optical drive is a relatively simple replacement. It must also be removed to access the keyboard.
你所需要的
Unscrew the single screw on the RAM access panel using a Phillips #0 screwdriver.
Use a plastic opening tool to pry off the access panel.
Remove two 2.5 mm screws from the side of the optical drive using a Phillips #0 screwdriver.
即将完成!
结论
