跳转到主内容
Toshiba TECRA R940 Hard Drive Replacement
你所需要的
  1. Toshiba TECRA R940 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,2 Toshiba TECRA R940 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,2
    • Loosen the screw holding the back panel for RAM in place using a Phillips #0 screwdriver. Once loosened, lift the panel up and set it aside.
    • The screw holding the panel in place should not come completely out. If it does, do not be alarmed as it will still screw back in.
  2. Toshiba TECRA R940 Hard Drive Replacement: 步骤 2 中的图像 1,2 Toshiba TECRA R940 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Remove the 11mm screw from the right side of the hard drive access panel using a Phillips #0 screwdriver.
    • Remove the 3.5 mm screw from the left side of the access panel using a Phillips #0 screwdriver.
    • Use a plastic opening tool to pry off the access panel from the bottom.
  3. Toshiba TECRA R940 Hard Drive Replacement: 步骤 3 中的图像 1,2 Toshiba TECRA R940 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Gently lift the hard drive from the left side and disconnect the SATA connector from the right side. Completely remove the hard drive.
结论
一条评论
I cannot lift up the “back cover” (step 1). I’ve twirled the screw left for minutes and tried to lift up the panel using a small flathead screwdriver and it will not lift up. HELP!
Remy Secor - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 18
总计 1,079
