简介
The CPU cooling fan is simple to replace and may need to be removed if the motherboard is replaced.
你所需要的
Unscrew the single screw on the RAM access panel using a Phillips #0 screwdriver.
Use a plastic opening tool to pry off the access panel.
即将完成!
结论
