简介
There are several access panels that make up the entire back panel of the Toshiba Tecra R940-S9421. You will learn how to replace all of them.
Completing this guide will also show you how to access all of the internal components of the laptop.
你所需要的
Unscrew the single screw on the RAM access panel using a Phillips #0 screwdriver.
Use a plastic opening tool to pry off the access panel.
即将完成!
结论
另外一个人完成了本指南。
