简介
In this tutorial you may learn how to disassemble the Toshiba Stor.E Alu 2S 2,5" without hurting anyone (including the HDD!). You may afterwards build in another 2,5" Device in the case or build the included HDD inside any PC. The Device can afterwards be completely rebuild just by reversing the instructions.
你所需要的
This is the portable HDD we start with. Your version may look different as they come white, silver or black. Anyway this tutorial will work on all of them without anyone bleeding.
We try to open the case by widening the outer frame with our sharp fingernails (alternatively you may use any sharp tool, but that might hurt this beautiful case...).
Keep in mind that there are two seperate halves of the outer case.
I've included photos of the edges that hold the outer case tight. Maybe knowing about those will help you.
13等其他人完成本指南。
2条评论
5 years ago but perfect still for a random job I had for it thankyou
My portable hard disk can not be used as internal hard / secondary hard disk. What should I do
