跳转到主内容
Toshiba Satellite p875 s7200 RAM Stick Replacement
你所需要的
  1. Toshiba Satellite p875 s7200 RAM Stick Replacement, RAM Stick: 步骤 1 中的图像 1,1
    • Remove the battery by sliding the tabs to the left.
    • Use the spudger to lift the battery out.
  2. Toshiba Satellite p875 s7200 RAM Stick Replacement: 步骤 2 中的图像 1,1
    • Use the Phillips head screw driver to remove the screw holding the back plate on.
    • Use the spudger to remove the back plate.
  3. Toshiba Satellite p875 s7200 RAM Stick Replacement: 步骤 3 中的图像 1,1
    • Unlock the RAM by lightly pushing the two metallic holding arms away from the RAM stick.
    • The holding arms can be pressed together or one at a time.
    • The RAM sticks one of its edges slightly away away from the computer when unlocked.
  4. Toshiba Satellite p875 s7200 RAM Stick Replacement: 步骤 4 中的图像 1,1
    • Grab the RAM stick by the protruding edge.
    • Pull the RAM stick towards the right to remove.
结论
Danny Amado
于10/29/18注册
823 声望
创作了5篇指南
团队
Baylor, Team S1-G3, Williams Fall 2018 Baylor, Team S1-G3, Williams Fall 2018 的会员
BU-WILLIAMS-F18S1G3
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 317
