跳转到主内容
Toshiba Satellite e205 Keyboard Replacement
你所需要的
  1. Toshiba Satellite e205 Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite e205 Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
    • With the battery away from you, slide the locking clips out.
    • The left clip stays, the right clip is spring loaded.
    • Slide the battery away from you.
  2. Toshiba Satellite e205 Keyboard Replacement, Keyboard: 步骤 2 中的图像 1,1
    • Use a spudger to carefully pry up the keyboard screw cover.
  3. Toshiba Satellite e205 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Remove the two screws securing the keyboard to the chassis.
  4. Toshiba Satellite e205 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Carefully tilt the keyboard towards you and release the ribbon cables.
    • Use a spudger if needed to release the latch. The latch slides out.
    • The keyboard is now free and can be set aside.
结论
2等其他人完成本指南。
Tyler
于06/19/12注册
4,920 声望
创作了16篇指南
团队
TechForce TechForce 的会员
Business
2 名成员
创作了25篇指南
2条评论
What is the brass colored ribbon for? Mine is broken will it effect funconality , if so how do i fix it
Kathleen T - 回复
If I remember correctly, this keyboard is backlit. Most likely the copper cable is for the backlit power. A new keyboard would need to be purchased to fix it.
Tyler - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 16
总计 652
