跳转到主内容
Toshiba Satellite c650d RAM Replacement
你所需要的
  1. Toshiba Satellite c650d RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Unplug the laptop and turn it off.
    • Flip the laptop upside down.
    • Locate the battery on the underside of the laptop.
  2. Toshiba Satellite c650d RAM Replacement: 步骤 2 中的图像 1,1
    • Push the two latches away from the battery.
  3. Toshiba Satellite c650d RAM Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite c650d RAM Replacement: 步骤 3 中的图像 2,2
    • Slide the battery away from the laptop.
    • Locate the serial number on the battery to order a replacement.
  4. Toshiba Satellite c650d RAM Replacement, RAM: 步骤 4 中的图像 1,1
    • Remove the one 5.5mm Philips #0 screw that holds in the central panel.
  5. Toshiba Satellite c650d RAM Replacement: 步骤 5 中的图像 1,1
    • Pull the back panel off.
  6. Toshiba Satellite c650d RAM Replacement: 步骤 6 中的图像 1,1
    • Remove the RAM.
    • Carefully undo the clips on either side of the top RAM.
    • Remove the chip by pulling it out of its slot.
    • Repeat until you have removed the chip that you want to replace.
    • This laptop has only two slots for RAM, and both are filled. Plan accordingly if your goal is to increase RAM.
结论
另外一个人完成了本指南。
Brenna Callahan
于10/21/15注册
868 声望
创作了5篇指南
团队
UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015 的会员
UMASSD-GULBRANDSEN-F15S5G2
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 15
总计 667
