跳转到主内容
Toshiba Satellite c650d Keyboard Replacement
你所需要的
  1. Toshiba Satellite c650d Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Unplug the laptop and turn it off.
    • Flip the laptop upside down.
    • Locate the battery on the underside of the laptop.
  2. Toshiba Satellite c650d Keyboard Replacement: 步骤 2 中的图像 1,1
    • Push the two latches away from the battery.
  3. Toshiba Satellite c650d Keyboard Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite c650d Keyboard Replacement: 步骤 3 中的图像 2,2
    • Slide the battery away from the laptop.
    • Locate the serial number on the battery to order a replacement.
  4. Toshiba Satellite c650d Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,1
    • Remove the fourteen 6.0mm and two 2.0mm Philip's #0 screws connecting the keyboard to the back.
    • Make sure you keep track of all the screws.
  5. Toshiba Satellite c650d Keyboard Replacement: 步骤 5 中的图像 1,1
    • Flip the computer over.
    • Use a nylon spudger to lift the keyboard.
    • Go around the edge of the keyboard and lift until the keyboard separates from the back.
    • Only lift the keyboard a little at a time, otherwise you risk damaging the plastic.
  6. Toshiba Satellite c650d Keyboard Replacement: 步骤 6 中的图像 1,1
    • Detach the ribbon cable that connects the keyboard to the motherboard.
结论
3等其他人完成本指南。
Brenna Callahan
于10/21/15注册
868 声望
创作了5篇指南
团队
UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015 的会员
UMASSD-GULBRANDSEN-F15S5G2
3 名成员
创作了10篇指南
4条评论
this is completely wrong, remove the strip above keyboard, unscrew the screws, lift keyboard up gently, remove ribbon cable by flipping up the catch, all should be done VERY gently
one78point4 - 回复
VERY TRUE . But fitted a new keyboard and it still can,t use numbers one to five or the space bar unless i use the FN button.
jcampbell1950 - 回复
Just proceeded as one78point4 commented and although it's a Toshiba L300, it took me less than 5 minutes to fix my keyboard's issue, which was in fact a disconnected ribbon (strange though...sabotage?)
Anyway...thanks a million to you one78point4!!!
calipha - 回复
as one78point4 commented this is total overkill and not at all correct, most Toshibas keyboards are removed in the way described by one78point4 and I should know I’ve replaced enough of them over the last 20 yrs, although later laptops are heaps easier than the old one.
transtasmancomputers - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 1,683
