跳转到主内容
Toshiba Satellite c650d Fan Replacement
你所需要的
  1. Toshiba Satellite c650d Fan Replacement, Battery: 步骤 1 中的图像 1,1
    • Unplug the laptop and turn it off.
    • Flip the laptop upside down.
    • Locate the battery on the underside of the laptop.
  2. Toshiba Satellite c650d Fan Replacement: 步骤 2 中的图像 1,1
    • Push the two latches away from the battery.
  3. Toshiba Satellite c650d Fan Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite c650d Fan Replacement: 步骤 3 中的图像 2,2
    • Slide the battery away from the laptop.
    • Locate the serial number on the battery to order a replacement.
  4. Toshiba Satellite c650d Fan Replacement, Keyboard: 步骤 4 中的图像 1,1
    • Remove the fourteen 6.0mm and two 2.0mm Philip's #0 screws connecting the keyboard to the back.
    • Make sure you keep track of all the screws.
  5. Toshiba Satellite c650d Fan Replacement: 步骤 5 中的图像 1,1
    • Flip the computer over.
    • Use a nylon spudger to lift the keyboard.
    • Go around the edge of the keyboard and lift until the keyboard separates from the back.
    • Only lift the keyboard a little at a time, otherwise you risk damaging the plastic.
  6. Toshiba Satellite c650d Fan Replacement: 步骤 6 中的图像 1,1
    • Detach the ribbon cable that connects the keyboard to the motherboard.
  7. Toshiba Satellite c650d Fan Replacement, Fan: 步骤 7 中的图像 1,1
    • Detach the cable connecting the fan to the motherboard.
  8. Toshiba Satellite c650d Fan Replacement: 步骤 8 中的图像 1,2 Toshiba Satellite c650d Fan Replacement: 步骤 8 中的图像 2,2
    • Remove the one 3.0mm and one 5.0mm Philips #0 screws holding the fan in place.
  9. Toshiba Satellite c650d Fan Replacement: 步骤 9 中的图像 1,1
    • Remove the fan by pulling it out slowly.
结论
4等其他人完成本指南。
Brenna Callahan
于10/21/15注册
868 声望
创作了5篇指南
团队
UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015 的会员
UMASSD-GULBRANDSEN-F15S5G2
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 1,422
