跳转到主内容
Toshiba Satellite U405D-S2902 RAM Replacement
你所需要的
  1. Toshiba Satellite U405D-S2902 RAM Replacement, RAM: 步骤 1 中的图像 1,2 Toshiba Satellite U405D-S2902 RAM Replacement, RAM: 步骤 1 中的图像 2,2
    • Lay the device face down with the battery facing away from you. Locate the center panel. It will have two vents in it and three screws on the left side.
    • Loosen the three screws that hold the rear access panel on, using your Phillips #1 Screwdriver.
    • The screws will not actually come out from the panel but will be loose and let the panel come off.
    • Lift the left side of the panel to remove it.
  2. Toshiba Satellite U405D-S2902 RAM Replacement: 步骤 2 中的图像 1,1
    • Locate and pull back the two mounting clips on either side of the memory chip.
    • Be sure that when replacing the board, push down gently until the clips snap back in.
  3. Toshiba Satellite U405D-S2902 RAM Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite U405D-S2902 RAM Replacement: 步骤 3 中的图像 2,2
    • Lift RAM circuit board to about a 45 degree angle and pull gently to the right.
结论
That's it for hardware, the remaining steps will depend on the software platform being run on your laptop.
2等其他人完成本指南。
Brandon Kirklen
于01/11/13注册
311 声望
创作了8篇指南
团队
Cal Poly, Team 7-8, Maness Winter 2013 Cal Poly, Team 7-8, Maness Winter 2013 的会员
CPSU-MANESS-W13S7G8
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 603
