跳转到主内容
Toshiba Satellite U405D-S2902 Keyboard Replacement
你所需要的
  1. Toshiba Satellite U405D-S2902 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,3 Toshiba Satellite U405D-S2902 Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,3 Toshiba Satellite U405D-S2902 Keyboard Replacement, Keyboard: 步骤 1 中的图像 3,3
    • Situate the laptop so that it is open and the display is facing you.
    • Use the plastic opening tool to pry the black plastic insert upward. The insert can be found at the top of the keyboard.
    • Once the insert is loose, carefully remove it from the device.
  2. Toshiba Satellite U405D-S2902 Keyboard Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite U405D-S2902 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Using #1 Phillips Screwdriver, remove both of the 5 mm screws that are located beneath the insert.
  3. Toshiba Satellite U405D-S2902 Keyboard Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite U405D-S2902 Keyboard Replacement: 步骤 3 中的图像 2,2
    • Use the plastic opening tool to begin removing the keys off of the device.
    • Once the keys are off, gently remove the keyboard. Be careful of the ribbon cable that still connects the keyboard to motherboard.
  4. Toshiba Satellite U405D-S2902 Keyboard Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite U405D-S2902 Keyboard Replacement: 步骤 4 中的图像 2,2
    • Lift up the gate on the ZIF socket to release the ribbon.
    • Ease the ribbon connecting the keyboard to the motherboard out of the ZIF socket.
结论
2等其他人完成本指南。
Brandon Kirklen
于01/11/13注册
311 声望
创作了8篇指南
团队
Cal Poly, Team 7-8, Maness Winter 2013 Cal Poly, Team 7-8, Maness Winter 2013 的会员
CPSU-MANESS-W13S7G8
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 600
