跳转到主内容
Toshiba Satellite U405D-S2902 Hard Drive Replacement
你所需要的
  1. Toshiba Satellite U405D-S2902 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,2 Toshiba Satellite U405D-S2902 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,2
    • Lay laptop on it's face and remove the two #1 Phillips screws in the back of the black plastic panel with a raised center.
    • The screws can not be removed from the panel, so loosen them until the panel can come off.
    • Carefully lift the panel using the thumb slot on the side closest to you while the battery is pointed out.
  2. Toshiba Satellite U405D-S2902 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • After lifting the cover up carefully, slide it to the left to be removed.
  3. Toshiba Satellite U405D-S2902 Hard Drive Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite U405D-S2902 Hard Drive Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite U405D-S2902 Hard Drive Replacement: 步骤 3 中的图像 3,3
    • Place two fingers gently on the hard drive.
    • Slide it back to the left.
    • Lift the drive by the two corner tabs making sure not to touch the metel
    • Do not press down too hard on the top of the drive, or you will damage it. Only use enough pressure to be able to remove it from the SATA connection.
结论
2等其他人完成本指南。
Brandon Kirklen
于01/11/13注册
311 声望
创作了8篇指南
团队
Cal Poly, Team 7-8, Maness Winter 2013 Cal Poly, Team 7-8, Maness Winter 2013 的会员
CPSU-MANESS-W13S7G8
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 12
总计 504
