跳转到主内容
Toshiba Satellite U405D-S2902 Cooling Fans Replacement
你所需要的
  1. Toshiba Satellite U405D-S2902 Cooling Fans Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure that the laptop is off and unplugged.
    • Turn the laptop over.
    • Slide back the left lock, and you should hear a click when it is successfully locked back in.
  2. Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 2 中的图像 1,1
    • Rotate the laptop 180 degrees so that the battery is near you.
    • Hold back the spring slide and pull the battery out.
  3. Toshiba Satellite U405D-S2902 Cooling Fans Replacement, Keyboard: 步骤 3 中的图像 1,3 Toshiba Satellite U405D-S2902 Cooling Fans Replacement, Keyboard: 步骤 3 中的图像 2,3 Toshiba Satellite U405D-S2902 Cooling Fans Replacement, Keyboard: 步骤 3 中的图像 3,3
    • Situate the laptop so that it is open and the display is facing you.
    • Use the plastic opening tool to pry the black plastic insert upward. The insert can be found at the top of the keyboard.
    • Once the insert is loose, carefully remove it from the device.
  4. Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 4 中的图像 2,2
    • Using #1 Phillips Screwdriver, remove both of the 5 mm screws that are located beneath the insert.
  5. Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 5 中的图像 2,2
    • Use the plastic opening tool to begin removing the keys off of the device.
    • Once the keys are off, gently remove the keyboard. Be careful of the ribbon cable that still connects the keyboard to motherboard.
  6. Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 6 中的图像 2,2
    • Lift up the gate on the ZIF socket to release the ribbon.
    • Ease the ribbon connecting the keyboard to the motherboard out of the ZIF socket.
  7. Toshiba Satellite U405D-S2902 Cooling Fans Replacement, Faceplate: 步骤 7 中的图像 1,2 Toshiba Satellite U405D-S2902 Cooling Fans Replacement, Faceplate: 步骤 7 中的图像 2,2
    • With the keyboard removed, locate the marked screws.
    • Remove the marked, 5mm screws using the #1 Phillips Screwdriver.
  8. Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 8 中的图像 1,2 Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 8 中的图像 2,2
    • In the opening above the mouse pad, use the plastic opening tool to push up the black gate of the ZIF socket.
    • Remove the ribbon from the ZIF socket.
  9. Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 9 中的图像 1,3 Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 9 中的图像 2,3 Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 9 中的图像 3,3
    • Locate the wide opening at the top near the screen.
    • Use the plastic opening tool to open the black ZIF socket.
    • Remove the blue ribbon.
  10. Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 10 中的图像 1,2 Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 10 中的图像 2,2
    • After removing the screw in step 3, carefully close the laptop and put it face down. Locate the center panel.
    • Remove the three, 3 mm screws using the #1 Phillips Screwdriver.
  11. Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 11 中的图像 1,2 Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 11 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Grasp the power cable with your tweezers and remove it from the wireless antenna.
  12. Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 12 中的图像 1,2 Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 12 中的图像 2,2
    • Locate and remove both the white and black antenna leads with the tweezers.
  13. Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 13 中的图像 1,3 Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 13 中的图像 2,3 Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 13 中的图像 3,3
    • Remove screws for back assembly.
    • 11 x F5 (5 mm #1 Phillips)
    • 6 x F2 (2 mm #0 Phillips)
    • 4 x F8 (8 mm #1 Phillips)
    • 1 x F3 (3 mm #1 Phillips
  14. Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 14 中的图像 1,1
    • Use the plastic opening tool to release the back panel from the laptop.
    • If all of the screws are removed it should come off with very little effort. Do not force it. If it still feels attached, check that you didn't miss a screw or two.
  15. Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 15 中的图像 1,2 Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 15 中的图像 2,2
    • Use the plastic opening tool to separate the top faceplate.
    • The faceplate is the plastic surface and the metal piece under the keyboard.
    • Carefully lift the faceplate off of the base by sliding the plastic opening tool around the outside of the device. You'll hear clicks as you do this.
    • Prying apart the faceplate will be a little hard, but try not to bend it too much - you do not want to crack it.
  16. Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 16 中的图像 1,1
    • Lift the back panel and carefully disconnect the main power cable.
  17. Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 17 中的图像 1,2 Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 17 中的图像 2,2
    • Remove the black signal cable attached at the blue circuit board.
  18. Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 18 中的图像 1,2 Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 18 中的图像 2,2
    • Remove auxiliary power cable attached to the blue board at the back of the laptop.
  19. Toshiba Satellite U405D-S2902 Cooling Fans Replacement, Cooling Fans: 步骤 19 中的图像 1,2 Toshiba Satellite U405D-S2902 Cooling Fans Replacement, Cooling Fans: 步骤 19 中的图像 2,2
    • Remove the fan mounting screws with a #1 Phillips Screwdriver.
  20. Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 20 中的图像 1,3 Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 20 中的图像 2,3 Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 20 中的图像 3,3
    • Locate and remove the heat sink mounting screws using a #1 Phillips Screwdriver.
    • These screws will be tight as they hold a critical component onto the processor. You may need to use a little extra elbow grease to remove them.
  21. Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 21 中的图像 1,2 Toshiba Satellite U405D-S2902 Cooling Fans Replacement: 步骤 21 中的图像 2,2
    • Carefully lift the fan and heat sink assembly.
    • Detach the fan power cable from the motherboard with your fingers by squeezing the white plastic connector and wiggling gently from side to side.
    • There will be a grey goop between the copper heat piping and the back of the processor, (indicated in pink). This is thermal paste and allows heat to flow properly.
    • Be sure to replace any missing thermal paste when installing the new fan.
结论
4等其他人完成本指南。
Brandon Kirklen
于01/11/13注册
311 声望
创作了8篇指南
团队
Cal Poly, Team 7-8, Maness Winter 2013 Cal Poly, Team 7-8, Maness Winter 2013 的会员
CPSU-MANESS-W13S7G8
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,338
