跳转到主内容
Toshiba Satellite U405D-S2902 Battery Replacement
  1. Toshiba Satellite U405D-S2902 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure that the laptop is off and unplugged.
    • Turn the laptop over.
    • Slide back the left lock, and you should hear a click when it is successfully locked back in.
  2. Toshiba Satellite U405D-S2902 Battery Replacement: 步骤 2 中的图像 1,1
    • Rotate the laptop 180 degrees so that the battery is near you.
    • Hold back the spring slide and pull the battery out.
结论
2等其他人完成本指南。
Brandon Kirklen
于01/11/13注册
311 声望
创作了8篇指南
团队
Cal Poly, Team 7-8, Maness Winter 2013 Cal Poly, Team 7-8, Maness Winter 2013 的会员
CPSU-MANESS-W13S7G8
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 523
