简介
This Replacement guide will be teaching you step by step how to replace the hard drive on you Toshiba Satellite S75D-A7346
你所需要的
First we have to take out the battery
Pull the switch on the left to the left
then hold the switch on the right to the right direction
then pull up the bttery from the point inbetween the 2 switches
Unscrew the screw located next to the information sticker
Then get a screw driver or prier to gently pry the covering plate
Unscrew the black screws and then pull the black tab to the right
Then lift it out and place it somewhere
Unscrew the silver screws and move the hard drive somewhere else
Screw the silver screws into the screw slots furthest away from the connectors
Note: This computer is only compatible with 2.5 inch SATA 3Gbps
Put the Hard Drive in slot (make sure the connectors are on the same side of the connectors
Push the Hard Driver into the connector and screw the black screws in
Put on the backplate and put pressure arround the edges of the blackplate so it stays flat with the case
Then screw in the screw next to the information sticker
Place the battery in the slot
Then hold the right switch to the right and push the battery in, then release the switch.
move the left switch to the right
另外一个人完成了本指南。
