跳转到主内容
Toshiba Satellite S55t-C5225 RAM Replacement
你所需要的
  1. Toshiba Satellite S55t-C5225 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Shut down the computer and disconnect all cables
    • Flip the computer over so the bottom is facing up.
  2. Toshiba Satellite S55t-C5225 RAM Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite S55t-C5225 RAM Replacement: 步骤 2 中的图像 2,2
    • Remove the two 7.0 mm Phillips #0 screws that hold the battery in place.
  3. Toshiba Satellite S55t-C5225 RAM Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite S55t-C5225 RAM Replacement: 步骤 3 中的图像 2,2
    • Carefully remove the battery by wedging a plastic opening tool in-between the battery and back cover.
  4. Toshiba Satellite S55t-C5225 RAM Replacement, Back Panel: 步骤 4 中的图像 1,2 Toshiba Satellite S55t-C5225 RAM Replacement, Back Panel: 步骤 4 中的图像 2,2
    • Remove the eleven 7.0 mm Phillips #0 screws that secure the back cover.
  5. Toshiba Satellite S55t-C5225 RAM Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite S55t-C5225 RAM Replacement: 步骤 5 中的图像 2,2
    • Wedge the tip of a plastic opening tool between the back cover and metal frame.
    • Twist the plastic tool, while wedged, to release the retaining tabs from the frame.
    • Repeat these steps around the laptop to release all retaining tabs.
  6. Toshiba Satellite S55t-C5225 RAM Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite S55t-C5225 RAM Replacement: 步骤 6 中的图像 2,2
    • Once all retaining tabs are released, pull up on the cover to remove.
  7. Toshiba Satellite S55t-C5225 RAM Replacement, RAM: 步骤 7 中的图像 1,3 Toshiba Satellite S55t-C5225 RAM Replacement, RAM: 步骤 7 中的图像 2,3 Toshiba Satellite S55t-C5225 RAM Replacement, RAM: 步骤 7 中的图像 3,3
    • Press on the metals clips on the outside of the RAM to release it.
    • Gently pull out the first RAM stick. Repeat the process for the other RAM stick.
结论
3等其他人完成本指南。
Javien Delgado
于10/21/19注册
220 声望
创作了2篇指南
团队
UMass Dartmouth, Team S1-G5, Botvin Fall 2019 UMass Dartmouth, Team S1-G5, Botvin Fall 2019 的会员
UMASSD-BOTVIN-F19S1G5
3 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 404
