跳转到主内容
Toshiba Satellite S55t-A5389 Wireless Network Card Replacement
你所需要的
  1. Toshiba Satellite S55t-A5389 Wireless Network Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the fourteen 5mm Phillips #0 screws from the bottom of the laptop.
  2. Toshiba Satellite S55t-A5389 Wireless Network Card Replacement: 步骤 2 中的图像 1,1
    • Using the plastic prying tools, go around the edge of the bottom of the laptop to release the cover.
  3. Toshiba Satellite S55t-A5389 Wireless Network Card Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite S55t-A5389 Wireless Network Card Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite S55t-A5389 Wireless Network Card Replacement: 步骤 3 中的图像 3,3
    • Remove the four 5mm Phillips #0 screws from the battery.
    • Unplug the battery from the motherboard.
    • Remove the battery from the laptop.
  4. Toshiba Satellite S55t-A5389 Wireless Network Card Replacement, Wireless Network Card: 步骤 4 中的图像 1,1
    • Disconnect the black and white antenna wires from the wifi card.
  5. Toshiba Satellite S55t-A5389 Wireless Network Card Replacement: 步骤 5 中的图像 1,1
    • Remove the 3mm Phillips #0 screw from the wifi card.
    • Remove the card from its socket.
结论
3等其他人完成本指南。
William Mazanec
于01/29/18注册
1,350 声望
创作了8篇指南
团队
USF Tampa, Team S5-G6, Passmore Spring 2018 USF Tampa, Team S5-G6, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S5G6
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 19
总计 1,644
