跳转到主内容
Toshiba Satellite S55T-B5335 Wi-Fi Adapter Replacement
你所需要的
  1. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the two 7 mm Phillips #1 screws that hold the battery in place.
  2. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: 步骤 2 中的图像 3,3
    • Pull the battery from laptop.
  3. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Bottom Cover: 步骤 3 中的图像 1,2 Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Bottom Cover: 步骤 3 中的图像 2,2
    • Remove the ten 7 mm Phillips #1 screws that secure the back cover.
  4. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: 步骤 4 中的图像 1,1
    • Wedge the tip of a plastic opening tool between the back cover and the metal frame.
    • Twist the plastic opening tool, while wedged, in order to release the retaining tabs from the frame.
    • Repeat these steps in a circular pattern around the laptop to release all retaining tabs.
  5. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: 步骤 5 中的图像 1,1
    • Once all retaining tabs are released from the frame, you can pull up on the back cover to remove it.
  6. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Wi-Fi Adapter: 步骤 6 中的图像 1,1
    • Using the pointed end of the Spudger, gently disconnect the antenna (white and black wires) from the Wi-Fi adapter.
  7. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: 步骤 7 中的图像 1,1
    • Remove the single 4 mm Phillips #1 screw holding the Wi-Fi adapter in place.
  8. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: 步骤 8 中的图像 1,1
    • While grabbing the Wi-Fi adapter on both sides, gently pull away from the socket in the direction of the removed screw.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 2-1, Blackwell Fall 2016 USF Tampa, Team 2-1, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S2G1
4 名成员
创作了7篇指南
一条评论
George, do you know where the graphics chip is at on that motherboard?
Any Where - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 1,127
