跳转到主内容
Toshiba Satellite S55T-B5335 Cooling Fans Replacement
你所需要的
  1. Toshiba Satellite S55T-B5335 Cooling Fans Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the two 7 mm Phillips #1 screws that hold the battery in place.
  2. Toshiba Satellite S55T-B5335 Cooling Fans Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite S55T-B5335 Cooling Fans Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite S55T-B5335 Cooling Fans Replacement: 步骤 2 中的图像 3,3
    • Pull the battery from laptop.
  3. Toshiba Satellite S55T-B5335 Cooling Fans Replacement, Bottom Cover: 步骤 3 中的图像 1,2 Toshiba Satellite S55T-B5335 Cooling Fans Replacement, Bottom Cover: 步骤 3 中的图像 2,2
    • Remove the ten 7 mm Phillips #1 screws that secure the back cover.
  4. Toshiba Satellite S55T-B5335 Cooling Fans Replacement: 步骤 4 中的图像 1,1
    • Wedge the tip of a plastic opening tool between the back cover and the metal frame.
    • Twist the plastic opening tool, while wedged, in order to release the retaining tabs from the frame.
    • Repeat these steps in a circular pattern around the laptop to release all retaining tabs.
  5. Toshiba Satellite S55T-B5335 Cooling Fans Replacement: 步骤 5 中的图像 1,1
    • Once all retaining tabs are released from the frame, you can pull up on the back cover to remove it.
  6. Toshiba Satellite S55T-B5335 Cooling Fans Replacement, Cooling Fans: 步骤 6 中的图像 1,1
    • Remove the two 3.5 mm Phillips #1 screws that hold the cooling fan in place.
  7. Toshiba Satellite S55T-B5335 Cooling Fans Replacement: 步骤 7 中的图像 1,1
    • Wedge the flat end of the spudger between the connector and its socket.
    • Twist back and forth in order to pry the connector loose from its socket.
    • Although you can pull on the connector wires to remove it from the socket, it is not recommended until the connector is loose to prevent damage to the wires.
  8. Toshiba Satellite S55T-B5335 Cooling Fans Replacement: 步骤 8 中的图像 1,1
    • Lift up on the cooling fan to remove it from the laptop.
    • Repeat steps 6-8 for the other cooling fan.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 2-1, Blackwell Fall 2016 USF Tampa, Team 2-1, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S2G1
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 1,417
