跳转到主内容
Toshiba Satellite S50-B Hard Drive Replacement
你所需要的
  1. Toshiba Satellite S50-B Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite S50-B Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure you turn off the laptop first.
    • Unscrew the two 6.5mm screws below the battery using a Phillips #0 Screwdriver.
  2. Toshiba Satellite S50-B Hard Drive Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite S50-B Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Place thumbs on corners of the battery. Pinch the battery between the thumb and index finger and pull.
  3. Toshiba Satellite S50-B Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,3 Toshiba Satellite S50-B Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 2,3 Toshiba Satellite S50-B Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 3,3
    • Locate the 12 screws on the bottom of the device. Unscrew using a Phillips screwdriver, and set screws aside.
    • Use a plastic opening tool to remove bottom casing.
  4. Toshiba Satellite S50-B Hard Drive Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite S50-B Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Use the plastic casing over the hard drive to lift the hard drive up.
    • Once hard drive is slightly lifted up, make sure the laptop is in correct orientation with the battery away from you, and pull the hard drive towards right.
结论
4等其他人完成本指南。
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 32
总计 6,020
