跳转到主内容
Toshiba Satellite S50-B Cooling Fan Replacement
你所需要的
  1. Toshiba Satellite S50-B Cooling Fan Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite S50-B Cooling Fan Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure you turn off the laptop first.
    • Unscrew the two 6.5mm screws below the battery using a Phillips #0 Screwdriver.
  2. Toshiba Satellite S50-B Cooling Fan Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite S50-B Cooling Fan Replacement: 步骤 2 中的图像 2,2
    • Place thumbs on corners of the battery. Pinch the battery between the thumb and index finger and pull.
  3. Toshiba Satellite S50-B Cooling Fan Replacement, Cooling Fan: 步骤 3 中的图像 1,3 Toshiba Satellite S50-B Cooling Fan Replacement, Cooling Fan: 步骤 3 中的图像 2,3 Toshiba Satellite S50-B Cooling Fan Replacement, Cooling Fan: 步骤 3 中的图像 3,3
    • Locate the 10 screws on the bottom of the device, there should be 12 screws in total including the battery screws. Unscrew using a Phillips #0 screwdriver, and set screws aside.
    • Use a plastic opening tool to remove the bottom panel.
  4. Toshiba Satellite S50-B Cooling Fan Replacement: 步骤 4 中的图像 1,3 Toshiba Satellite S50-B Cooling Fan Replacement: 步骤 4 中的图像 2,3 Toshiba Satellite S50-B Cooling Fan Replacement: 步骤 4 中的图像 3,3
    • Locate the 2 screws on each fan. Unscrew them.
    • Disconnect the fan by applying gentle pressure to the circled connection with your finger and pulling.
    • Remove the fans. Be sure to keep track of the right and left fans, marked R and L.
结论
另外一个人完成了本指南。
diana calvo
于10/17/17注册
144 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 1,465
