跳转到主内容
Toshiba Satellite P855-S5312 Keyboard Replacement
你所需要的
  1. Toshiba Satellite P855-S5312 Keyboard Replacement, Battery: 步骤 1 中的图像 1,3 Toshiba Satellite P855-S5312 Keyboard Replacement, Battery: 步骤 1 中的图像 2,3 Toshiba Satellite P855-S5312 Keyboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Turn laptop upside down with the spine facing towards you and locate the two tabs on the top of the back panel.
    • Move the sliders to the left and right to release the tabs holding the battery in.
    • While the tabs are pushed outwards, remove the battery from the device.
  2. Toshiba Satellite P855-S5312 Keyboard Replacement, Keyboard: 步骤 2 中的图像 1,3 Toshiba Satellite P855-S5312 Keyboard Replacement, Keyboard: 步骤 2 中的图像 2,3 Toshiba Satellite P855-S5312 Keyboard Replacement, Keyboard: 步骤 2 中的图像 3,3
    • Using plastic spudger to pry up the edges of the keyboard and lift it towards the screen.
    • Unplug the ZIF connector ribbon using the plastic spudger by gently prying the edges of the plug.
    • Remove the keyboard from the device.
结论
To reassemble your device, plug the ribbon into circuit board and snap the replacement keyboard in place.
Dalton
于10/02/17注册
215 声望
创作了2篇指南
团队
USF Tampa, Team S10-G2, Thompson Fall 2017 USF Tampa, Team S10-G2, Thompson Fall 2017 的会员
USFT-THOMPSON-F17S10G2
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 1,207
