跳转到主内容
Toshiba Satellite P855-S5312 Fan Replacement
你所需要的
  1. Toshiba Satellite P855-S5312 Fan Replacement, Battery: 步骤 1 中的图像 1,3 Toshiba Satellite P855-S5312 Fan Replacement, Battery: 步骤 1 中的图像 2,3 Toshiba Satellite P855-S5312 Fan Replacement, Battery: 步骤 1 中的图像 3,3
    • Turn laptop upside down with the spine facing towards you and locate the two tabs on the top of the back panel.
    • Move the sliders to the left and right to release the tabs holding the battery in.
    • While the tabs are pushed outwards, remove the battery from the device.
  2. Toshiba Satellite P855-S5312 Fan Replacement, Keyboard: 步骤 2 中的图像 1,3 Toshiba Satellite P855-S5312 Fan Replacement, Keyboard: 步骤 2 中的图像 2,3 Toshiba Satellite P855-S5312 Fan Replacement, Keyboard: 步骤 2 中的图像 3,3
    • Using plastic spudger to pry up the edges of the keyboard and lift it towards the screen.
    • Unplug the ZIF connector ribbon using the plastic spudger by gently prying the edges of the plug.
    • Remove the keyboard from the device.
  3. Toshiba Satellite P855-S5312 Fan Replacement, Fan: 步骤 3 中的图像 1,3 Toshiba Satellite P855-S5312 Fan Replacement, Fan: 步骤 3 中的图像 2,3 Toshiba Satellite P855-S5312 Fan Replacement, Fan: 步骤 3 中的图像 3,3
    • Unscrew the one 1.5mm screw using a Philips #0 screwdriver holding the L shape panel.
    • Pry up the panel to gain access to hidden screws.
  4. Toshiba Satellite P855-S5312 Fan Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite P855-S5312 Fan Replacement: 步骤 4 中的图像 2,2
    • Remove the fourteen (14) screws using a Philips #0 screwdriver for the 1.5mm screws on the underside of casing.
  5. Toshiba Satellite P855-S5312 Fan Replacement: 步骤 5 中的图像 1,3 Toshiba Satellite P855-S5312 Fan Replacement: 步骤 5 中的图像 2,3 Toshiba Satellite P855-S5312 Fan Replacement: 步骤 5 中的图像 3,3
    • Unscrew the nine 1.5mm screws using a Philips #0 screwdriver under the keyboard with the F6 printed next to them.
    • Unplug the three no-fuss ribbon cable connector cables by gently pulling on them away from you towards the keyboard.
  6. Toshiba Satellite P855-S5312 Fan Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite P855-S5312 Fan Replacement: 步骤 6 中的图像 2,2
    • Pry apart the casing with the plastic opening tool.
    • Removing the cover under keyboard.
  7. Toshiba Satellite P855-S5312 Fan Replacement: 步骤 7 中的图像 1,3 Toshiba Satellite P855-S5312 Fan Replacement: 步骤 7 中的图像 2,3 Toshiba Satellite P855-S5312 Fan Replacement: 步骤 7 中的图像 3,3
    • Unplug the single no-fuss cable connector using the plastic opening tool pushing the edges towards the fan.
    • Unscrew the two 1.5mm screws using a Philips #0 screwdriver by the head mounting holding down the fan.
    • Pull the fan up and remove it from the device.
结论
Dalton
于10/02/17注册
215 声望
创作了2篇指南
团队
USF Tampa, Team S10-G2, Thompson Fall 2017 USF Tampa, Team S10-G2, Thompson Fall 2017 的会员
USFT-THOMPSON-F17S10G2
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 561
