跳转到主内容
Toshiba Satellite P855-S5312 Disk Drive Replacement
你所需要的
  1. Toshiba Satellite P855-S5312 Disk Drive Replacement, Battery: 步骤 1 中的图像 1,3 Toshiba Satellite P855-S5312 Disk Drive Replacement, Battery: 步骤 1 中的图像 2,3 Toshiba Satellite P855-S5312 Disk Drive Replacement, Battery: 步骤 1 中的图像 3,3
    • Turn laptop upside down with the spine facing towards you and locate the two tabs on the top of the back panel.
    • Move the sliders to the left and right to release the tabs holding the battery in.
    • While the tabs are pushed outwards, remove the battery from the device.
  2. Toshiba Satellite P855-S5312 Disk Drive Replacement, Disk Drive: 步骤 2 中的图像 1,2 Toshiba Satellite P855-S5312 Disk Drive Replacement, Disk Drive: 步骤 2 中的图像 2,2
    • Once laptop is turned over with the spine facing you, locate the large L shape panel.
    • Using a Philips #0 screwdriver unscrew the 1.5mm screw towards the bottom of the laptop.
  3. Toshiba Satellite P855-S5312 Disk Drive Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite P855-S5312 Disk Drive Replacement: 步骤 3 中的图像 2,2
    • Open the motherboard access cover.
  4. Toshiba Satellite P855-S5312 Disk Drive Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite P855-S5312 Disk Drive Replacement: 步骤 4 中的图像 2,2
    • Using a Philips #0 screwdriver, unscrew the 1.5mm screw located near the left edge of the opening near the mother board.
  5. Toshiba Satellite P855-S5312 Disk Drive Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite P855-S5312 Disk Drive Replacement: 步骤 5 中的图像 2,2
    • Gently pull the entire disk drive assembly out.
  6. Toshiba Satellite P855-S5312 Disk Drive Replacement: 步骤 6 中的图像 1,3 Toshiba Satellite P855-S5312 Disk Drive Replacement: 步骤 6 中的图像 2,3 Toshiba Satellite P855-S5312 Disk Drive Replacement: 步骤 6 中的图像 3,3
    • Flip your device over and rotate the side of the optical drive over to you.
    • Unclip the clips on the side of the automatic release.
    • Use a paper clip or small needle tool to insert in the manual release located on the right of the automatic release button.
    • Once released slide the aluminum case out.
结论
Bishop Clark
于10/02/17注册
225 声望
创作了2篇指南
团队
USF Tampa, Team S10-G2, Thompson Fall 2017 USF Tampa, Team S10-G2, Thompson Fall 2017 的会员
USFT-THOMPSON-F17S10G2
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 14
总计 470
