跳转到主内容
Toshiba Satellite P775-S7320 Screen Replacement
你所需要的
  1. Toshiba Satellite P775-S7320 Screen Replacement, Screen: 步骤 1 中的图像 1,2 Toshiba Satellite P775-S7320 Screen Replacement, Screen: 步骤 1 中的图像 2,2
    • Begin by removing all of the screws around the perimeter of the screen. There are 6 total.
  2. Toshiba Satellite P775-S7320 Screen Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite P775-S7320 Screen Replacement: 步骤 2 中的图像 2,2
    • Gently remove the plastic lining of the screen. Use a card, guitar pic, or another tool to pry open the lining, but be careful during this process.
  3. Toshiba Satellite P775-S7320 Screen Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite P775-S7320 Screen Replacement: 步骤 3 中的图像 2,2
    • Once the plastic lining is loose from the device, you can remove the lining. Gently pop the lining of the screen off of the hinges of the computer.
  4. Toshiba Satellite P775-S7320 Screen Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite P775-S7320 Screen Replacement: 步骤 4 中的图像 2,2
    • Unscrew the screws located on the sides of the silver part of the screen. Some of the screws are smaller than others, so be sure to get all of them. The screen cannot come off if the screws are not all out.
  5. Toshiba Satellite P775-S7320 Screen Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite P775-S7320 Screen Replacement: 步骤 5 中的图像 2,2
    • At this point, your screen is almost disconnected. Be sure to support the screen because there is nothing holding it up.
  6. Toshiba Satellite P775-S7320 Screen Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite P775-S7320 Screen Replacement: 步骤 6 中的图像 2,2
    • Gently remove the tape from the screen. After you have done so, your screen is ready to be replaced!
结论
Addie Reames
于10/10/16注册
219 声望
创作了2篇指南
团队
Texas Tech, Team 6-5, Bennett Fall 2016 Texas Tech, Team 6-5, Bennett Fall 2016 的会员
TTU-BENNETT-F16S6G5
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 882
