跳转到主内容
Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement
  1. Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement, Battery: 步骤 1 中的图像 1,1
    • First flip the device over so that the back side is facing upwards
  2. Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: 步骤 2 中的图像 1,1
    • Push the two sliders toward the edge of the laptop.
    • Remove the battery.
  3. Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement, Hard Drive: 步骤 3 中的图像 1,1
    • First, remove the screw holding the hard drive cover in place.
  4. Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: 步骤 4 中的图像 1,3 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: 步骤 4 中的图像 2,3 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: 步骤 4 中的图像 3,3
    • Lift the cover and set it aside.
  5. Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: 步骤 5 中的图像 1,1
    • Remove the hard drive.
  6. Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement, Speakers: 步骤 6 中的图像 1,3 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement, Speakers: 步骤 6 中的图像 2,3 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement, Speakers: 步骤 6 中的图像 3,3
    • Remove all of the screws labeled F8 from the backside of the device.
  7. Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: 步骤 7 中的图像 1,3 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: 步骤 7 中的图像 2,3 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: 步骤 7 中的图像 3,3
    • Flip the device over and open it up.
    • Using your pry tool begin to pop the keyboard upwards starting from the side closest to the screen. You will hear an audible "pop" sound.
  8. Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: 步骤 8 中的图像 1,3 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: 步骤 8 中的图像 2,3 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: 步骤 8 中的图像 3,3
    • After popping the keyboard off you need to disconnect the keyboard from the motherboard.
  9. Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: 步骤 9 中的图像 1,2 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: 步骤 9 中的图像 2,2
    • Remove the two screws labeled F8 in the shown places.
  10. Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: 步骤 10 中的图像 1,1
    • Remove the optical drive from the device. Just pull it out.
  11. Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: 步骤 11 中的图像 1,2 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: 步骤 11 中的图像 2,2
    • The next step is to unplug the speakers from the motherboard. The wire shown is the speaker wire.
  12. Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: 步骤 12 中的图像 1,3 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: 步骤 12 中的图像 2,3 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: 步骤 12 中的图像 3,3
    • Next, take your pry tool again and start to lift around the edge of the device. Once you get it lifted enough, use your hands to pop the top panel of the base of the device.
  13. Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: 步骤 13 中的图像 1,2 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: 步骤 13 中的图像 2,2
    • Next, remove the wires from the the small clips holding them in place.
  14. Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: 步骤 14 中的图像 1,3 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: 步骤 14 中的图像 2,3 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: 步骤 14 中的图像 3,3
    • Lastly, remove the two screws holding the speaker in place.
    • After doing that you will be able to just lift up on the speaker to remove it.
    • Repeat Steps 8 and 9 for the other speaker.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 232
