简介
This guide will show you how to replace the computer's display screen. Replacing the display screen is necessary when the screen won't turn on or it's cracked. Before conducting our steps, please make sure your computer is powered off.
配件
无需配件。
  1. Open the laptop and unscrew each of the screws that are in the corners of the screen using a Phillips #1 screwdriver. Open the laptop and unscrew each of the screws that are in the corners of the screen using a Phillips #1 screwdriver.
    • Open the laptop and unscrew each of the screws that are in the corners of the screen using a Phillips #1 screwdriver.
  2. Using a metal spudger, insert the spudger around the edges and the bottom to detach the frame from the screen. Using a metal spudger, insert the spudger around the edges and the bottom to detach the frame from the screen. Using a metal spudger, insert the spudger around the edges and the bottom to detach the frame from the screen.
    • Using a metal spudger, insert the spudger around the edges and the bottom to detach the frame from the screen.
  3. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. Remove the frame from the device.
    • Remove the frame from the device.
  5. Using a Phillips #1 screwdriver, unscrew all of the screws on the sides of the screen. Using a Phillips #1 screwdriver, unscrew all of the screws on the sides of the screen. Using a Phillips #1 screwdriver, unscrew all of the screws on the sides of the screen.
    • Using a Phillips #1 screwdriver, unscrew all of the screws on the sides of the screen.
  6. Disconnect the webcam from the screen and unhook any tape. Disconnect the webcam from the screen and unhook any tape.
    • Disconnect the webcam from the screen and unhook any tape.
  7. Remove the display from the device.
    • Remove the display from the device.
结论
Mayra Zuniga
于2018年01月17日注册
279 信誉积分
创作了2篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 6
总计 117
