简介
Use this guide to remove the Toshiba Satellite P55t-A5116 Keyboard.
你所需要的
视频概述
Close laptop and turn it upside down
Remove the 14 circular rubber covers with tweezers along with one smaller more cylindrical rubber cover.
Use the #PH0 screw head, remove 4 (5.7mm) screws.
Unplug the battery's 10 pin connector and gently lift the battery out of the laptop.
Using the #PH0 screw head, remove 2 (5.7 mm) screws.
Remove metal plate.
Using the #PH0 screw head remove 1 (5.7mm) screw and 1 (4.15mm) screw.
Using a PH0 screwdriver, remove 2 (5.7mm) screws.
Using a PH0 screwdriver, remove 4 (3.68mm) screws.
Pull out the latches on either side.
The RAM should pop up.
Remove the RAM.
Repeat for the other side.
3等其他人完成本指南。
2条评论
This is by far the most informative instructions I have ever come upon. Not only does it explain the keyboard removal (which was my issue), but also explains the removal of pretty much every component that might need to be replaced excluding the screen. Thumbs up! I will definitely refer all my friends all colleagues to iFixit. Again Thumbs up!
Make certain you view the comment at Step 3, it’s hidden unless you click on it. May save you time…
