跳转到主内容
Toshiba Satellite P55t-A5116 Battery Replacement
你所需要的
  1. Toshiba Satellite P55t-A5116 Battery Replacement, Back Casing: 步骤 1 中的图像 1,2 Toshiba Satellite P55t-A5116 Battery Replacement, Back Casing: 步骤 1 中的图像 2,2
    • Close laptop and turn it upside down
    • Remove the 14 circular rubber covers with tweezers along with one smaller more cylindrical rubber cover.
  2. Toshiba Satellite P55t-A5116 Battery Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite P55t-A5116 Battery Replacement: 步骤 2 中的图像 2,2
    • Using the #PH0 screw head, remove 14 (5.7 mm) screws from the back casing.
  3. Toshiba Satellite P55t-A5116 Battery Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite P55t-A5116 Battery Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite P55t-A5116 Battery Replacement: 步骤 3 中的图像 3,3
    • Gently pry off the bottom case with the plastic opening tools.
    • Find the seam between the back case and the rest of the laptop casing.
  4. Toshiba Satellite P55t-A5116 Battery Replacement, Battery: 步骤 4 中的图像 1,2 Toshiba Satellite P55t-A5116 Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • Use the #PH0 screw head, remove 4 (5.7mm) screws.
    • Unplug the battery's 10 pin connector and gently lift the battery out of the laptop.
  5. Toshiba Satellite P55t-A5116 Battery Replacement: 步骤 5 中的图像 1,1
    • Gently remove battery from the laptop.
结论
12等其他人完成本指南。
9条评论
The screws for the battery are in very tight and I'm having trouble unscrewing them
Brianna Brucale - 回复
I'm having difficulty unplugging the 10 pin connector. Afraid if I pull too hard it will pull the wires out. Any suggestions?
jmomenee - 回复
Just wiggle it back-and-forth a bit and it should come out. I just change my own battery.
Carmen Cuevas -
I did all of that but my laptop didn’t reboot, any suggestions
roberta - 回复
I had no problem installing the new battery, but even after letting it charge over 24 hours. Not able to get it to turn on
roberta - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 35
总计 22,720
