跳转到主内容
Toshiba Satellite P55W-C5316 Screen Replacement
你所需要的
  1. Toshiba Satellite P55W-C5316 Screen Replacement, Back Panel: 步骤 1 中的图像 1,2 Toshiba Satellite P55W-C5316 Screen Replacement, Back Panel: 步骤 1 中的图像 2,2
    • To prevent injury, ensure the laptop is powered off before starting your work.
    • Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
  2. Toshiba Satellite P55W-C5316 Screen Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite P55W-C5316 Screen Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite P55W-C5316 Screen Replacement: 步骤 2 中的图像 3,3
    • Be careful to not crack the panel where the USB and power cord ports are.
    • Insert the opening tool in between the back panel and the laptop to pry it open.
    • The back panel is magnetically attached at the front of the laptop so you may have to move the opening tool along the length of the panel.
    • Lift the panel from the front off of the laptop.
  3. Toshiba Satellite P55W-C5316 Screen Replacement, Fan: 步骤 3 中的图像 1,1
    • Remove both screws from the fan.
  4. Toshiba Satellite P55W-C5316 Screen Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite P55W-C5316 Screen Replacement: 步骤 4 中的图像 2,2
    • Remove the screws securing the 4 corners of the heatsink.
    • Gently remove the heatsink. Keep in mind thermal paste is used and it may be slightly difficult to remove.
  5. Toshiba Satellite P55W-C5316 Screen Replacement: 步骤 5 中的图像 1,3 Toshiba Satellite P55W-C5316 Screen Replacement: 步骤 5 中的图像 2,3 Toshiba Satellite P55W-C5316 Screen Replacement: 步骤 5 中的图像 3,3
    • Remove the small, beige colored connector securing the fan to the laptop and remove the fan and heatsink assembly from the laptop.
  6. Toshiba Satellite P55W-C5316 Screen Replacement, Screen: 步骤 6 中的图像 1,2 Toshiba Satellite P55W-C5316 Screen Replacement, Screen: 步骤 6 中的图像 2,2
    • Using the Phillips #00 screwdriver, remove the two screws securing the silver USB protector located on the far right side of the laptop, and pry off the protector.
    • Remove the three screws at the top end of the USB protector using the Phillips #00 screwdriver.
  7. Toshiba Satellite P55W-C5316 Screen Replacement: 步骤 7 中的图像 1,1
    • Using the Phillips #0 screwdriver, remove the screws on metal hinge securing the screen to the laptop.
    • There was only a single screw at the time of guide creation but you should remove any screws from the hinge.
  8. Toshiba Satellite P55W-C5316 Screen Replacement: 步骤 8 中的图像 1,1
    • Repeat the previous step to remove the screws on the other hinge securing the display to the device.
  9. Toshiba Satellite P55W-C5316 Screen Replacement: 步骤 9 中的图像 1,2 Toshiba Satellite P55W-C5316 Screen Replacement: 步骤 9 中的图像 2,2
    • Remove all of the black tape securing the hinge to the laptop.
  10. Toshiba Satellite P55W-C5316 Screen Replacement: 步骤 10 中的图像 1,1
    • Disconnect the connector directly above the IO cable.
  11. Toshiba Satellite P55W-C5316 Screen Replacement: 步骤 11 中的图像 1,1
    • Remove the display assembly from the device.
结论
Kyle Dierking
于11/07/19注册
133 声望
撰写一个指南
团队
IUPUI, Team S2-G1, Harley Fall 2019 IUPUI, Team S2-G1, Harley Fall 2019 的会员
IUPUI-HARLEY-F19S2G1
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 11
总计 672
