跳转到主内容
Toshiba Satellite P55W-C5316 Battery Replacement
你所需要的
  1. Toshiba Satellite P55W-C5316 Battery Replacement, Back Panel: 步骤 1 中的图像 1,2 Toshiba Satellite P55W-C5316 Battery Replacement, Back Panel: 步骤 1 中的图像 2,2
    • To prevent injury, ensure the laptop is powered off before starting your work.
    • Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
  2. Toshiba Satellite P55W-C5316 Battery Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite P55W-C5316 Battery Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite P55W-C5316 Battery Replacement: 步骤 2 中的图像 3,3
    • Be careful to not crack the panel where the USB and power cord ports are.
    • Insert the opening tool in between the back panel and the laptop to pry it open.
    • The back panel is magnetically attached at the front of the laptop so you may have to move the opening tool along the length of the panel.
    • Lift the panel from the front off of the laptop.
  3. Toshiba Satellite P55W-C5316 Battery Replacement, Battery: 步骤 3 中的图像 1,3 Toshiba Satellite P55W-C5316 Battery Replacement, Battery: 步骤 3 中的图像 2,3 Toshiba Satellite P55W-C5316 Battery Replacement, Battery: 步骤 3 中的图像 3,3
    • The battery is located in the bottom right corner of the laptop.
    • Remove the four .5mm Phillips head screws on the battery using the PH1 screwdriver.
  4. Toshiba Satellite P55W-C5316 Battery Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite P55W-C5316 Battery Replacement: 步骤 4 中的图像 2,2
    • Do not tug on the cord or battery. Instead, pull evenly on the connector.
    • Lift the battery and gently pull out the bundled cable connector.
结论
3等其他人完成本指南。
Alec Bonnell
于10/18/17注册
497 声望
创作了4篇指南
团队
UMass Dartmouth, Team S3-G2, Bailey Fall 2017 UMass Dartmouth, Team S3-G2, Bailey Fall 2017 的会员
UMASSD-BAILEY-F17S3G2
3 名成员
创作了7篇指南
一条评论
Hello, please I've been searching and searching online to get motherboard for Toshiba Satellite P55W-C5316 but i don't seen to find any. Can anyone lead me to get one to buy.
Owusu Bright - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 21
总计 2,789
